What high-end portable rec's have mic->usb connectivity for recording/broadcasting capabilities?
Do you want a device that is both,
digital field recorder with built in mics and USB audiointerface for your computer?
(not just a USB-port for dragging files from the device to your PC)
I know the Zoom H4N (edit- and the OLympus LS-100 as well) has what I want, but what are the alternatives? I'd like to record audio on the device AND use it as a USB input. Thanks for quick response.
From the descriptions I've read so for I'm not sure, if these recorders act as "real" audiointerfaces ( analog -> digital and digital -> analog) or like basic USB-microphones (analog -> digital) and if they support ASIO. (on Win you would want that for realtime fx, etc. stuff)
Whats your application? (recording speech, interviews or music)
If music:
Do you want play with effects like reverb, guitar amp simulation etc. in realtime (!)?
Do you want play with software-based instruments?
Do you just want to record on device and into the computer, but add effects etc. later on?
I'm not very knowledgeable about pocketrecorders, I only had a Boss unit once,
but I think the Zoom H4N is a nice sweetspot and they seem to be pretty common with musicians.
For more high-end sound I would go with dedicated mic + audiointerface + laptop/tablet/smartphone.
But of course this solution wouldn't be as simple and elegant as only a pocketrecorder.
My main concern is redundancy. I will use it for interviews/meetings as I am the president of a college group and need something better than my current setup. I'd like the audio to pass through but still record. :/
So you want to record on the pocketrecorder and on a computer at the same time through the recorder?
