USB hubs with remotely switchable ports
Does anyone have recommendation for USB hubs that have ports you can remotely toggle on/off? I need to connect some cameras and I would like to be able to remotely plug cycle them. For my use the ports don’t need to be super fast and I only need 4 ports (but faster and more is fine too).
Almost every usb hub I own is switchable, but I don’t have a single one that can do it remotely. That’s a very interesting idea. Excepting something ultra fancy like usb anywhere and the like, I’m not sure this exists. But, you could probably build one DIY quite easily as you just need some kind of microcontroller and some beefy transistors (you could even hang it off the same bus!)
OK I researched a little more and found a couple things:
If the goal is to power cycle cameras that have flaked out, then you could put a smart switch on the powered hub and toggle them all at once. I do that will my POE cameras. One of them stops pinging and NodeRed power cycles the POE switch.
Hmm yeah I guess it wouldn’t suck to power cycle them all, I don’t really have to be able to do them individually.
