USB hub for virtualbox VMs
Is there a way to setup a usb hub to use with virtual machines in virtual box?
Wouldn't anything you plug into it be able to passthrough to the VM?
Ive had issues in the past, was wondering if there is a way to specifically get one for VMs
Not sure on the software side, as do USB hubs generally even show up as devices?
But hardware wise I think you could get a KVM switch and use that on the single computer to do it, possibly, same thing with switching your keyboard/mouse and making them dedicated to the virtual machine I think
Definitely an interesting alternative. I'm gonna try a few more things on the software side first, but I didnt even consider hardware before
