USB-C as DP on Ryzen APU?
The specification for USB type C includes the use of the port as a display port. Most B350 and X370 boards don’t have a DP beside a HDMI port.
Is it possible to use the type C as a DP on Ryzen boards?
Does it matter whether it is connected directly via the CPU or indirectly via the southbridge?
The USB-port would need to support DP Alt mode, in which case it would work.
Yes, I thought so.
Is anyone able to test and confirm?
