I’m doing a lazy USB-C mod of an FEXT controller, which uses micro USB.
I have a micro USB (M) to USB-C (F) cable that works well without being large enough to cause trouble when trying to close the case, but it falls just short of the SDL port cutout. A simple 90 degree coupler (type C M to type C F) would be enough to reach it, and I’ve found plenty of candidates on Amazon, but the problem is the quality seems to be utter garbage.
Does anyone have any recommendations? All I need is something durable, doesn’t matter what USB version.
Edit: To clarify, I just want something flat like this:
Thanks for the recommendation. I bought a couple of the Delocks, but since they’ll take a couple months to arrive in the US, I also ordered a cheapo adapter off Amazon.
