USB Audio Interface becomes distorted after short time - various distros
Hi all, Linux noob here with some audio problems. I’ve got a multichannel USB audio interface (MOTU 1248) that seems to not play well with some aspect of Ubuntu-based distributions. Built-in audio and HDMI audio to monitor work fine. I’ve tried various Ubuntu-based distros over the last ten years or so and my USB interfaces have all “just worked” and IIRC I’ve even tried this one previously and it’s worked fine. Relevant output from aplay-l is:
card 2: D1248 [1248], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
I’ve tried Ubuntu Studio, KDE Neon, and I’m currently troubleshooting on Ubuntu 18.10. Symptoms of the problem are:
  • Main problem: playing audio through USB interface works for a short time (~30secs) then audio becomes distorted and output is suddenly on all output channels instead of just the two with source audio.
  • When first connected only shows as multichannel input, no outputs available
  • When interface is reconnected multichannel output will show up
  • The interface has the ability to choose how many channels it presents to the PC. No matter how many or how little I choose (2 or 24) the profile is still multichannel audio
  • Have tried with various buffer sizes and problem persists. Sample rate matches pulseaudio config.
  • Have tried with various USB ports, 2.x and 3.x and problem persists
  • Even in Ubuntu Studio with JACK the problem persists, though Pulseaudio WAS still running bridged to JACK.
So long story short, USB audio bad. Built-in audio good. Any ideas?
After some more testing it seems like what is happening is that one of the many services responsible for audio decides to increment my output ports by 8. For example, if I’m in Ardour and sending tone to the master which is routed to outputs 1+2 then after some time it distorts and audio moves to outputs 9+10 of it’s own accord. If I keep it going it will then move down to 17+18.
Any idea of where to even start with this? This interface is class-compliant. I can use it with my iPad and even my Pixel XL (I’ve tried!) and it has worked in Ubuntu Studio in the past.
