USB Audio Crackling
KVM Model:
1.4 Display Port KVM Switch Single to 4
10
Problem:
I have a Jabra 510 USB speaker plugged, when using it with my Win 11 machine there is crackling audio. The crackling is not present when using with my Mac or Linux connected via the KVM or when connecting the speaker directly to the Win11 machine.
Other Notes:
The ground loop isolators reco’d in other posts don’t appear to work in my case because I’m not using an audio jack.
Naturally, the crackling sound is usually the culprit of an analog connection, but this is digital.
If it’s not present in MAC or Linux, but it is on Win11, then that would suggest it is something related to your Win11 machine. Can you try reinstalling audio drivers? Maybe you could try Nvidia or AMD audio solutions? You could try Nvidia Broadcast to see if the problem persists and/or can be fixed with their tools:
If not, I’d probably try a cheap USB DAC
Can you link the specific USB speaker you’re using
