so for @wendell might be a fun video if you can get pluggables to sponsor it
and this is more a thought experiment, but I got the idea from a question over here about multiple machines being replaced with one from a VM
Could you do a passthrough to a VM of an ultra dock, like this which is a USB 3.0 dock with display options, and a ton of connectivity including Ethernet, DVI/HDMI, and audio stuff, and then how would that work exactly? Would you be able to give each virtual machine a direct internet line, and it's own monitor and all that hooked up to the dock? would your GPU even matter in this case for getting displays to each machine?
I'm also unsure how cost effective this would be given the price of the PC + 3 docks compared to just buying a few dedicated PCs, I guess this may use less power than that overall though, especially with a higher end PSU, might be worth it for a business in that case.
This would be the build for it, dunno if the GPU would matter, so picked one with 4 mini display port outputs, and 8320e, so 2 cores per machine + 2 for host, with an SSD for each should be more than enough for basic office tasks, and then you could also like throw in a 4TB drive and have each VM be able to access it to save work to it right?
motherboard is there for the 4 USB 3.0 ports for the dock, but I'm sure you have hardware lying around you could do it with if you were to go with the video route
PCPartPicker part list: http://pcpartpicker.com/p/zHThnQ
Price breakdown by merchant: http://pcpartpicker.com/p/zHThnQ/by_merchant/
CPU: AMD FX-8320E 3.2GHz 8-Core Processor ($126.99 @ SuperBiiz)
Motherboard: ASRock 970M PRO3 Micro ATX AM3+/AM3 Motherboard ($56.99 @ SuperBiiz)
Memory: G.Skill Ares Series 16GB (2 x 8GB) DDR3-1600 Memory ($56.99 @ Newegg)
Storage: Sandisk SSD PLUS 120GB 2.5" Solid State Drive ($42.92 @ Amazon)
Video Card: ATI FirePro W4100 2GB Video Card ($159.99 @ Newegg)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case ($34.99 @ Micro Center)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply ($55.99 @ SuperBiiz)
Total: $663.62
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-03-24 22:01 EDT-0400
