I only have free USB 3 ports on my pc, anyway to make my 360 Controller work in one?
It should work fine? I have my USB 2 mouse and keyboard plugged into USB 3 ports? Plus my controller works in USB 3, you should be fine
1st. plug it in
2nd. let windows install the driver
3th. use it
Wasn't that hard. :)
(USB Ports are backward compatible)
I plug it in but it doesn't recognize it. Idk whats wrong
I believe Windows 8 or 8.1 has some bugs when it comes to USB 3.
backwards compatible. should be.
