URGENT - Need Help Migrating OS To Smaller Volume
My 840 Evo just arrive, but my SSD is much smaller than my HDD. Anyone know a tool that will let me migrate just the OS to the SSD?
Thanks
have you not tried the samsung migration tool that comes with ssd on the cd?
also are you just trying to copy the OS and installs on it?
Sorted it. I decided I wanted to go to a clean install, and due to lack of DVDs, I reset my Windows on Raid 0, transferred it to the SSD. It worked
I recently did this on my server. I tried to restore install the new hard drive then restore the drive with windows server backup/restore. Since the hard drive i was using to replace was smaller it would not allow it. so I went back into with the old hard drive and went to disk management and shrunk the volume to a size equal to or smaller than the drive i was using to replace it with. Performed a backup for that new shrunk volume, replaced the hard drive and restored with out a problem. Everything is up and running perfectly. i performed this on a Windows server 2012 machine
