UPS Noise Reduction / Silent UPS / Please Help Me Find a Good "Office" UPS
I need to find a UPS for my office. Since I also record audio in my office and don’t want to be disturbed by any noise, I would like to get a silent UPS or at least one that is very quiet.
I am looking for 1200-1500 watts like the new Eaton UPS 1440W 5PX1500RTG2 can provide. While the UPS seems perfect for me from the specs, size, etc. I checked the spec sheet and found the following information:
Line Mode: <40dB
Buck/Boost mode: <45dB
Battery mode: <45dB, 50dB for 3K
Fan shuts off when fully charged at <30% load in normal/line mode to reduce noise
https://www.eaton.com/content/dam/eaton/products/backup-power-ups-surge-it-power-distribution/backup-power-ups/eaton-5px-g2-ups/5px-g2-resources--na/eaton-5pxg2-tech-specs-td153033en.pdf
A few questions about this:
  1. 40dB is still quite a lot, are there any quieter options out there?
  2. Where is the noise coming from? If it is just the fan, switching to a Noctua might make it quieter. I am not sure how dangerous it is to open/tinker with UPS systems. Usually I can find a recommendation against it.
  3. Does anyone have this model and can confirm if the 30% load fan stop works? Does the fan immediately ramp up to the 40dB when the system is under 35% load?
Thanks!
I guess what you want is a Line Interactive UPS (which your selected Eaton is). These sit idle and jump in when a power outage occurs. Then they not only beep but the “stuff inside” makes some noise while the battery drains. All other types of UPS are always loud because the constantly “go through the battery” and convert from AC to DC and back again. And because they are “always on” the interruption (“Transfer time”) is way shorter.
I don’t know why exactly it would make <40dB noise while above 30% load in normal/line mode, but I guess you are correct and it’s just a fan. Even at 98% efficiency in line mode means 2% power lost, and that usually goes to heat and that has to go somewhere.
My APC BackUPS-Pro 900 is silent while in line mode, but that wouldn’t be enough for your VA requirements. I wouldn’t open a UPS more than what is required to change the battery. Modding a UPS is dangerous and could kill you if you don’t know what you are doing. Heavily DO NOT RECOMMEND!
So either you go up the models so the 30% load never occurs while recording or hopefully someone here has a 5PX G2 and can confirm the stated behavior (if it has to be the 5PX). Or maybe go with the 5S 1500VA, it only has <25 dbA @ 1m. Or another Tower style UPS, Rack Mountable usually tend to be louder because the racks usually stand where noise wouldn’t be an issue.
Oh, and also, W ≠ VA. Depending of the efficiency of your devices you may have to go up a class. And don’t go after the labels of the power supplies, do some measurements with a Kill-A-Watt or better yet something that does tracking by itself.
My CyberPower Line-interactive UPSes are completely silent when line power is present. The only time they make noise is when they’ve switched to battery and are running their inverters.
Most UPSes should allow you to silence the AC power loss alarm as well.
Thank you for your response. I agree with you, modifying a UPS does not seem like a good idea. Why can’t Eaton charge me 50 USD more and add Noctua fans?
I want to keep all my tech stuff organized in an open frame rack, so rackmountable would be what I need/want. What would be the quietest option?
Online UPSes aren’t really designed for use in a home environment, they’re designed for enterprise or other commercial use where they’re off in their own room separate from everything else.
My cyberpower 1500VA is completely silent, only noise I’ve ever heard from it is the click of the relays during power “blinks”/brownouts. I’ve not had a prolonged outage that made it draw from battery to know what that sounds like. If silence is the utmost goal and you’re not subject to normal/frequent power loss, the best solution may be multiple units like this, assuming you can split the power load. IIRC it’s 1000W
Well, my office is also enterprise…
What exact model do you have?
I don’t have the purchase link and there is no model number that I can find accessible on the unit, so I’m not 100% sure, but I believe it’s this
https://www.newegg.com/cyberpower-cp1500pfclcd-nema-5-15r/p/N82E16842102134?Item=N82E16842102134
This is at least the functional equivalent, if not exact SKU (it’s been a few years).
I have 2 of those, and one of the bigger 1500w brothers, they have a bit of a hum when on battery power, but are otherwise silent under normal grid power.
The other option is a solid state always on power supply, like a power supply:
https://www.pico-box.com/en-us/
connected to a battery
being charged with a fanless charger.
Be aware that most lifepo4 batteries don’t like being discharged faster than 1c for 30 seconds, so size a battery that will startup your pc and monitor.
ie a budget 100ah 12v battery can put put out 1200 watts for 30 seconds, and 600 watts for 2 hours.
An expensive but well regarded option is the viktron multi plus. People say that the fan doesn’t turn on till 70%, but you may want to call their sales staff and ask about a specific model. The multi plus line are charger/inverters offering (and electronics) bypass mode with a less than 20ms cutover time in case of power outage.
If you need long time power for a sound studio you may also want to look into eg4 batteries to run a small office for a few hours to a few days including heat/cooling.
I’ve been happy with Cyberpower true sine wave (they also make approximate sine wave, you save a little $). BUT…
One thing I discovered for my Cyberpower model was that the battery failure mode was that the UPS TURNED OFF even though it was still receiving wall power. Other brands I have used (mostly APC) continued to function when the battery died, beeping every few minutes. If you intent to use this somewhere where it might be unattended for a while and you won’t be able to hear the beeps and/or won’t have remote monitoring setup, that could be annoying. So if you need that, make sure the brand/model you pick has it.
You’re essentially creating a double-conversion UPS with that. Make sure your input power supply can handle the load of whatever you’re running off of it.
UPSes will beep and make a “click” (relay) sound when the voltage sags and the UPS steps-in, even if only momentarily. They also generate an electrical hum from the inverter when acting as a UPS. Besides power fluctuations, you’ll also get this when the UPS does a self-test…
You’ll want to check the product manual to confirm you can fully silence the alarm during normal operations (as opposed to silencing it after it starts beeping). That’s generally the opposite of what people want… being notified loudly when the circuit the UPS is on loses power.
You should take the extra precautions of removing the battery and disconnecting the UPS from power overnight (several hours) before opening one to make modifications.
A UPS is exactly the kind of device that can easily be located outside of your recording studio, and just be connected via extension cord, so that the noise doesn’t matter, and there’s not likely to be anyone interested in producing a silent unit for such a tiny market. If you needed something like that, switching your PC to a DC power supply and just running it directly from batteries instead of an AC UPS would work much better.
Which is part of the wonder of the victron multiplus. You can configure what your wall can supply, then add a battery to supplement peak demand, automatically recharging the battery during low demand. Have a 15 amp power plug in the closet that is your home lab, Have a Super NAS server that requires 3.5 KW during disk spin up, but 500w otherwise? Some batteries and the victron multiplus can solve that for you.
I looked up that model number and you’re apparently talking about a $1000 piece of kit. Just call up their sales department and ask.
Hey, I’m looking for a UPS for my recording studio, and I notice that the datasheet for the 5PX1500RTG2 says it produces, “less than 40dB,” when mains power is present and it’s in line mode. How much less? Because that’s a very large range, and it includes both “zero” and “rather loud”.
In addition to like, actual features and build quality, part of what you’re paying for with the 5X price premium over the same-VA-rated consumer gear is people to answer questions like this.
So what accounts for the premium price?
The name, the support, and hopefully a lower rate of incidents like this.
P.S. depending on the quality of your local utility infrastructure, it’s quite possible for a UPS to make your power supply less reliable. Especially if they don’t seamlessly pass through AC when the battery dies, and aren’t on top of battery replacements. Lead-acid batteries, unfortunately, are made of lead and weigh a metric shitton, so even the cheap ones are expensive.
I’m late to the conversation but have the same need,
I need a silent 2500w ups for my home PC. The one I have has 3 fans and I’ve had to muffled it (later on this).
Someone somewhere please direct me to a silent UPS.
I’m flexible: if its near load for a long time (2200-2500w) ok let the fans kick in, but otherwise, silent.
Also it cannot be the size of a fridge, hopefully no bigger than a 2-3u 4u rackmount (preferably even smaller)
No, I do not want to apply my own words from “the Zen of air cooling” to a UPS and engineer it myself.
—me and electricity… we don’t get along.
So I need a silent UPS, 2500w
…did I mention silent?
