Ok so ive seen the video obviously! i have a fx 4100 CPU with a Gigabyte M68MT-S2 motherboard
Is it posible to use this with the same motherboarD?
What is the limit for the gpu ( bottlenneck)?
thanks
thanks
If the FX-4100 works with your motherboard, then you should be able to throw an 8350 in there because they both use the same CPU socket. You might have to update your bios though.
As far as bottlenecking goes, you won't run into one. You might get a bottleneck if you start running three or four cards in SLI or Crossfire, but you should be fine other than that.
And how do I do a BIOS upgrade?
you need to go to www.gigabyte.com support and downloads the site guide from there.
OK, is it complicated to replace the CPU ??? I also have a small fan connected??
