I am upgrading to windows 11. I want this install to last at least 6 years. I was wondering for any tips to make this install as similar to win7/8.1 as possible meaning i want OS to leave me alone, without offering tips and alerts. I want to be able to restart my system at the time of my choosing without waiting 30 minutes for windows to “work on something”.
I heard Ian and others have their custom install builds that removes some of the nonsense from installation. Is there any such build u can recommend ? And maybe some guide to quickly remove onedrive and similar nonsense ?
Google perfect windows 11 install script by Chris Titus, you can cut out a lot of the crap the Microsoft tries to get away with by using it. It’s pretty easy to follow. Not sure if I can post a link but here it is:
When creating a USB installer with Rufus, there are options to cut out a lot of things during install, like automatically turning off everything in the Privacy section.
Chris Titus thing looks very very interesting ! Can i expect any problems in the future, with updates, like breaking win install because i removed something ?
I used the Chris Titus script just a few days ago actually since I had to move over to 11 after a power outage corrupted my stuff (was easier to just reinstall my 10 system that was being bogged down by years of use and programs etc. since I had backups). All it is is a one stop shop for installing programs, useful tweaks like restoring 10’s file explorer context menus, and OOShutup, which are all just fine to use and I was already using them on my other Windows installs. This just makes the whole process MUCH more convenient. Huge rec.
