Upgrading Thinkpad x201 tablet Wireless card HELP?
I don’t know which model you get for my Thinkpad x201 tablet, is there a possible way to get an AC wireless card? or is there a newer wireless card that I can buy to upgrade my current one? mine is the original one that was installed from the factory.
This is the one I have 11 b/g/n Wireless LAN mini-PCI Express Adapter II
I think any Mini PCI Express Wireless N card should work. I have a Atheros N card in my X61 and it does well. The only issue is you would need to flash the BIOS with Middleton BIOS to whitelist the wireless card. Hope this helps.
