I need help with some parts and all that. I dont really know what I am going for. I want a gaming PC but I do record sometimes. i have already upgraded the ram to 12 GB so that part is fine. I need some help for parts that will let me run the newer games on highest settings.
My current build: (Ignore everything in Swedish these parts are not hardware. Also my RAM is 12GB not 4GB)
i would say some form of h.26 encoding hardware would be your best bet. Because a gtx 560 is still a very powerful GPU and 6 cores, though they arnt the best designed cores, still work very well.
to run games at their highest setting I would recommend first upgrading your GPU to at least a Radeon 7950, GTX 760, 670, or 770, depending on how much you want to spend of course. I would strongly recommend getting a 4GB nVidia card for future proofing though as with my Radeon 7950 I have surpassed 2GB of VRAM usage. Currently from nVidia I like the EVGA 4GB cards with the ACX cooler, they look good, have great cooling performance, and with GPU boost 2.0 lower temps mean more boost.
For increasing your recording performance I don't think you can get a better price to performance boost than with a FX 8350. With that CPU being a 125W TDP you would probably want to upgrade your mobo to something like an Asus Sabertooth, but that probably isn't something you would have to do right away. I just dont feel safe putting a hotter CPU on a cheaper board. However if you are video RENDERING than I would at least go with a i7 Haswell or Ivy Bridge, but they will be a more expensive upgrade.
Lastly I would recommend two things, a 120GB SSD for your OS and a couple of your favorite games, and a 650 Watt Seasonic or Corsair PSU for more headroom. I only say those PSUs because I have worked with both brands and everything they make is quality stuff.
Youve got a pretty decent system as it is, and newer games should start to use CPU's better and more efficiently. So it depends on your cash situation, if you got a bit of spare cash lying around then sure upgrade some parts but if you havn't i really wouldn't be too concerned at this point as your PC should perform slightly better on newer games than the older ones currently out.
