Currently i have :
Mobo: Asrock 990FX extreme3
GPU: AMD Radeon HD 7700
CPU: AMD FX 6300
RAM: Corsair vengence DDR3 8GB
No after market cooler
Non modular psu dont no the make (used it for a year now)
And a crappy case that offers no cable managment and is loud
I have £70 give or take could get more and need to upgrade either the Cpu fan (have a stock one) or the case atm and i am wondering what the best option would be, and what i should upgrade say in a years time (full specs can be listed if needed)
I have also asked a question of which case would be the best and if you have any suggestions then please leave them
https://teksyndicate.com/forum/cases-chassis/need-%C2%A370-case/177984
All help is welcomed
http://www.logicalincrements.com/
Hyper 212, and a Corsair 200r
really need some more options but i do like the hyper 212
If it is more than 70.. then I would get this: http://uk.pcpartpicker.com/p/X077
If you cant get more then this: http://uk.pcpartpicker.com/p/1gpBw
I like the NZXT source 220 because it comes with 2 fans and they do quality stuff. You can put the fans in the front for good dust control and cooling.
If you have less than 70 then I would recommend this: http://uk.pcpartpicker.com/p/1ytsb
This is a underappreciated case that also comes with 2 fans and lots of room for cable management.
source 220 might not have the clearance for a hyper 212
I looked around and found that it does fit. There are lots of images on google of the two fitting together. It is close, but it fits without problems.
i do want the hyper 212 but ill probably save seperate money for that and spend around 70 on a case because im going to keep it for a while (3 years plus) so it would need to be big enough to store any future upgrades
Really need some help on what to do
I would recommend some of these for around that price range:
http://uk.pcpartpicker.com/part/fractal-design-case-fdcacore3000usb3bl
http://uk.pcpartpicker.com/part/corsair-case-300rwindowed
http://uk.pcpartpicker.com/part/corsair-case-cc9011028ww
http://uk.pcpartpicker.com/part/fractal-design-case-fdcadefr4ti
Any of these are good. The antec P280 is also good if you can find it on sale in a store or something.
Hi Forum
I have an older computer I'd like to upgrade but I'm a near total newbie so I need the advice of some veterans on how to boost it up to maximum. The computer is a HP Pavilion p6313w
Thanks
Please make a new thread!
