Upgrading my Case
So I'm finally breaking down upgrading my old Antec 1200 Case to a new Corsair Graphite 780T series case. (YAY).
 I sorta want to swap out the fans that are included with higher end aftermarket fans, but the case includes:
Front: 2 x 140mm
Rear:  1 x 140mm
I don't know exactly what I want to do with the fans. It supports top mounted fans at the roof of the case too.
I sorta want to swap the 2 140mm fans with 3 120mm fans just so its 3 fans pushing air which would seem like more air is being moved I assume.
Here are my choices:
(Using built in case fan controller) (only supports 5 fans)
Front 2x140mm
Rear 1x140mm
Top  2x140mm
(Use aftermarket fan controller that'll take up one optical bay slot)
Front either 2x140mm or 3x120mm
Rear 1x140mm
Top 2x140mm or 3x120mm
(OR use the built in case fan controller with a aftermarket controller like this one)
Rear 1x140mm
Any suggestions on this would be greatly appreciated. Also I'm looking for good aftermarket fans that are quiet and push a lot of air. (plain design not looking for LEDs or anything.)
If it were me, and I had all the money, I would max that thing with these things.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835608049&cm_re=noctua-_-35-608-049-_-Product
So bit of a delay in posting been busy with work and the holidays but I switched cases finally.
Replaced my Antec 1200 with a Corsair 780T, replaced the old Corsair 1000W PSU with a new Corsair RM1000W PSU. Applied some new thermal paste and added a new fan to my headsink for a push pull set up.
So far I'm LOVING the new case. Its whisper quiet, getting into the case is stupid easy and I have so much room now for stuff in it. I went from having like 45C idle to 30C idle right off the bat which I'm happy about and with the fans set to max I don't hear even a hum. I still got a bit of cable management to do on the backside of the case and maybe tie down some cables (such as my GPU cables).
Thanks for the support, please comment on the build.
Build Images
