The motherboard is a bit expensive, I don't think you're entering any extreme overclocking contests so just get a ~$150 one. eg. Sabertooth 990FX, Gigabyte-UD4H. Also since you're going AMD try to get 1866 ram over 1600 for overclocking purposes.
Zapan man I don't think people would be discriminating because of a swiss IT dealer I think people just didn't notice your post. BTW I think your components are fine but if I were you I'd downgrade the mobo.
@CapatinPip Thanks for the Tip with the Ram wasn't really sure about what frequenze I should take.
@Lortinator Hm. Actually that was my try of a joke. Not very sucessfull obviously. I might have forgotten the smiley. ^^" Thanks for the tip though. I will go over my joice of the Mobo again.
