Upgrading and need help fine tuning part list
So I am planning on upgrading from an athlon 2 x4 640 with a gtx 560ti to a new build for primarily gaming but possibly some light video editing and more likely some live streaming.
This is what I plan on upgrading to http://uk.pcpartpicker.com/user/LunchboxSpec/saved/nbtNnQ.
Some things to note are that I already have the PSU and the HDD and I don't intend on buying both 970's at once. Will do some overclocking and currently only playing on 1080p but this will probably change in the future, most likely when I get the second 970.
Anything that needs changing please let me know. I live in the UK and this is about the budget that I plan to spend. This needs to last a minimum of about 4 years
Final note is that it doesn't have to be a blue colour scheme but I do want it to look good.
Edit - Would also like to know how the i5 will handle two 970's
Is your psu similar and recent as the one on pcpartpicker? On the website output is [email protected],  If so, you're good to go.
Yeah it is the same. Only got it about 2 or 3 months ago.
build looks good... the i5 is a fine gaming processor and shouldn't bottleneck anything... I might consider splurging on a bit better motherboard... as low-end mobos with high-end parts seems a bit out of balance (and a computer is the sum of it's parts)... but if you looked over the features and decided that's all you need... build it and have fun gaming...
If you're after a nice blue/black themed motherboard - checkout the z97 asrock boards - extreme 6 or above:
http://uk.pcpartpicker.com/part/asrock-motherboard-z97extreme6
i5 will be fine, i7 would be ideal so you get HT.
Just be sure to update the firmware on the 840 evo as soon as you get it.
I would recommend reusing the 780Ti on the new build and wait for the gen 2 drop of the 900 series Nvidia GPUs ... also the MSI Z97-G55 SLI that you selected is OK at best for overclocking it is an 8 phase power design  ... for more serious OCs I would suggest the
http://uk.pcpartpicker.com/part/msi-motherboard-z97gd65gaming
MSI Z97-GD65 Gaming ATX LGA1150 Motherboard as it has a very good  12 phase power design and much better on board sound .... well worth the 30 quid... it will change the color scheme though   lol
Edit ... I know the price on the 3TB Seagate is tempting but read these before making your choice
http://www.zdnet.com/who-makes-the-most-reliable-hard-disk-drives-backblaze-has-updated-its-stats-7000034008/
http://www.pcworld.com/article/2089464/three-year-27-000-drive-study-reveals-the-most-reliable-hard-drive-makers.html
http://www.computerworld.com/article/2486820/data-center/read-this-before-you-buy-another-hard-drive.html
The Hitachi Deskstar 7K4000 may cost more to start with but  ... it is worth it
I plan on getting most parts on black friday so if the deal is good enough I will get the i7. Would I get much benefit to HT now or would it be something that is more utilised in the future.
I have a 560Ti and the 3TB Seagate already from my current build. I will look into investing a little bit more into the motherboard as well since you think I can get more for my money by spending a bit more.
