I'm thinking of upgrading some parts of my current build. It's going to be mainly used for video editing (using Adobe CC) and some photo editing. It's not going to be a gaming machine, beyond some very occasional bits and pieces anyway.
Its current specs are:
Intel i7 2600 3.4GHz (non-k version)
8GB 1333MHz RAM
Asus P8P67M Pro motherboard
Sapphire AMD 5770 1GB
Intel 520, 80GB SSD boot drive
My main questions are would I be best getting more 1333MHz RAM, or going for faster RAM? Is it worth upgrading the GPU for video editing and what would be the best option if so? Finally, is it worthwhile to make these upgrades rather than doing a new Haswell build instead?
The budget is fairly open, but I'd rather stick to the best value-for-money options where possible. Any other tips would be appreciated! Thanks.
It has be proven that unless you have an APU the frequency of the ram does not matter, only the quantity. As for the CPU, that sandy i7 is great, there is no point upgrading. The only part you should consider upgrading is that video card. I don't know the prices of the new R9 series but I'm guessing that the 7950 is still the winner at price/performance and it's a great video card.
The 650 ti boost 2gb is a very capable card for just photoshop. It is about 150 dollars right now. You don't need an extremely fast card(7950 or above) unless you are also gaming/video editing. You can go for the 7950 if you have the money but the 650 ti boost is fine for what you need it for. Whenever I build a pc I try to get 1600mhz speed ram but that is only because it helps in desktop applications. 1333 is fine so just get more.
