Upgrading a first gen ryzen build
Hey, currently this is my PC:
It has it’s problems, the GPU started to die after a power outage but all in all it was an excellent purchase, it lasted me for almost 6 years, linux support is fantastic and i couldn’t have been more satisfied. Now I’m planning my next build and I’d like it to last for at least as much as the current build has.
Initially i was planning on waiting for the next generation but the thing is, prices here in Brazil are insanely low for GPUs right now and i’m not sure how long they’ll remain that way, i could get a 6800XT for cheaper than the normal price of a 6700XT.
My initial plan was to start buying as soon as raphael launched, but having bought ryzen 1800X and 5700XT on launch i know how bad leap generations can be for hardware compatibility and driver support. I was thinking instead of buying the next gen as soon as it arrives to use that money on a 1440p ultrawide OLED monitor (that i was planning to get later on anyway) and a 6800XT, then wait around a bit until prices and drivers stabilize. This seems like a good plan but i have some concerns:
  • Bottleneck doesn’t concern me but i do have a concern about my mobo, it’s a X370 sli plus and i’ve had issues with it before when upgrading to newer hardware such as an M.2 that just didn’t get recognized by the bios, so i had to wait around until MSI published a BIOS update (which doesn’t happen often for the X370 anymore). While i don’t think the GPU could cause these problems, specially one that isn’t new, it’s something that worries me about this change.
  • While long term the CPU and MOBO don’t concern me because i’ll replace them in the next year, the GPU kind of locks me in place. If i buy a 6800XT i’ll probably have to stick to it for a little while and i’m not sure how future proof it is for 3440x1440 gaming.
  • If i were to pick a 6800XT, it would have to be asrock and i’ve been using sapphire since rx 580 days due to reliable build quality. I don’t have experience with asrock so i’m on the fence with that too, wendell making a video with an asrock 6750 is what made me even consider this purchase, otherwise it wouldn’t have crossed my mind.
What do you guys think and what would you do in the same situation?
GPUs are incredibly hard to future proof right now. All we know for sure is that Raytracing will become more and more important, but the 6800 XT should be a solid purchase and last you for at least 3 years. It should be able to provide 60Hz gaming until 2027, although some of the 2027 games might require you to push details down to medium and turn off Raytracing.
As for AMD, if you are o.k. with updating your BIOS and stick to a rolling stable until June next year, AM5 will be great. If not, wait until Q1 2023 before you pull the trigger. By then both Linux and BIOS support should be more or less there.
I’d say expecting any GPU to remain relevant in 2027 is a stretch. Don’t care what spec you bought.
We are on the cusp of mainstream ray tracing , process node advances and multi chip packages.
Expect big leaps. Anything you buy today will be irrelevant fairly fast.
True, but with a caveat - what is your use case?
If it is to enjoy the latest eye candy on a 4k@248Hz screen then yes, today the 2080 Ti released 2018 is pretty much irrelevant and has been ever since Cyberpunk came out.
If your use case is stable FPS on high settings with perhaps a feature or two turned off, The 2080 Ti is still a viable card though, and should be through the entire Lovelace generation (RTX 4000). Heck, even the 1080 and 1080 Ti is viable for 60Hz 1440p gaming today, though next gen will make that nonviable.
Completely, 100% agree with this, though a 6800 XT should still hold until 2027 just not the absolutely latest eye candy.
Oh absolutely, i usually take my time with games and i don’t mind fidgeting with settings so i’m definitely not looking for ultra settings gaming on 240hz. Also i wasn’t thinking of keeping the 6800XT until 2027, just for a year or two, perhaps until the 8000 series, i think it’s reasonable to trade it by then as long as the rest of the PC can hold on to for longer, which seems to be the goal for this new generation.
I’ll think about it and likely make the purchase.
One last thing though, do you folks have experience with asrock? I really trust sapphire, but the choice is between sapphire 6800 and asrock 6800XT. I’ve never bought anything from asrock so i’m unsure on how good it’s build quality is.
No idea, look to reviews. It appears to be this card:
https://www.asrock.com/Graphics-Card/AMD/Radeon%20RX%206800%20XT%20Phantom%20Gaming%20D%2016G%20OC/
Which, according to reviews, is just fine, but i have no experience personally.
Yeah i’ve seen a few reviews, wendell’s included, but i’m more worried about long term build quality and usually reviews only cover the performance aspect with very little long term usage.
Most brands are hit-and-miss, I’ve yet to encounter a single hardware brand that does everything perfect across the board. Well, except Apple 2005-2015 of course.
Furthermore, this can even vary between different products of the same product line; the MSI B350 Tomahawk had pretty shoddy quality, the MSI B450 Tomahawk had awesome quality and the MSI B550 Tomahawk had good quality.
If you are worried about breakage better to look at things like how does the brand deal with refunds and recalls? Any data on that?
In the end though, there will always be a chance your specific card will break due to freak conditions like a power surge from your PSU getting out of sync for a split second that then fries a capacitor on the board that then fries the entire board. Don’t think too hard about this even though it is good to keep your eyes open.
Disagree. My 2017 Titan XP is still better than the majority of cards out there today. It isn’t as good as newer cards obviously, but it can still pull its own weight. (GPU userbenchmark benches it at 17 out of 684 as I write this.)
" The Nvidia Titan Xp averaged 42.4% higher than the peak scores attained by the group leaders. This is an excellent result which ranks the Nvidia Titan Xp near the top of the comparison list."
If you invest in quality, it lasts. If you are struggling with your GPU after 3-4 years, you underbought. The MSI SUPRIM X 3090 I bought on release will last me a very long time.
Buy sapphire.
Asrock are ok for motheboards (I have one and a small form factor asrock beebox) but sapphire are premium amd GPU.
Your titan is from an era of stagnation.
The next 5 years are going to be very very different from the last 5.
I’ve got a 6900xt. I’m expecting it to be shit tier by 2025.
I’ve got the same impression. My 5700XT lasted this long because not much has changed from 2017 to today. It’s only now starting to hang because we have new engines and techniques in fresh titles.
Technology has advanced at roughly the same rate for the last 30 years. The chart below is CPU focused, but GPU progress are about the same. My 3090 will still be VR capable and play the games I need for the next 4 years (it’s a year old now.) When the 4090 comes out my card will still work as well as today.
The mindset of comparing what you have to the shiniest and newest available is flawed. That’s the way vendors want you to think because you only have 8 shades of green instead of the newly released 10 shade model they want you to buy. Convincing you that you simply must update makes them money. Instead, what you need to do is ask yourself, ‘does this video card do what I need?’ If yes, then it doesn’t matter how good the latest and greatest is. You have what you need. If Bob down the road gets a Whizzmatic 6000, that does not invalidate what’s sitting on your desk.
While i agree that generally the pace is pretty stable, it does have it’s bumps.
If you always have the highest end of every generation, you’re likely immune to it. But if you bought a 5700xt like i have, there’s a very clear distinction between recent games and everything else 5 years before. This is not to say that there was a huge advancement in hardware, but a different type of requirement in software, screen resolution and it’s technologies, which is extremely natural.
When the original DOOM came out it didn’t mean that current hardware became instantly more advanced, but that the software requirement for that type of usage increased in a very short time due to a specific technology. The bar got higher.
The usual “go-to” is Crysis. :smiley:
