I've already posted about this before about a week ago, I'm just gonna repost an updated version.
System Specs:
i5 4670k 4.6ghz
gtx 780 Ti classified SLI
asus maximus vi formula
16gb ddr3 1600
Corsair ax860
samsung 840 evo 250gb // WD caviar black 1 TB
1440p display @ 110hz
I upgraded from a 4gb gtx 670 SC to 2 gtx 780 ti classfieds. I have been having freezing problems in battlefield 4 ever since. Just a freeze that lasts around 5 seconds usually.(1 of them resulted in a BSOD). They seem to happen randomly. I can go 30 minutes without a freeze, or It can freeze like 10 times in a single match. Just gonna throw it out there, dont try and say its because BF4 has alot of issues, Im aware of them. I've never had this problem prior to putting these cards in. I also tried Tomb Raider, it froze after about 30 min and I had to hard reset. The cards were not OC'd. I've done a good amount of troubleshooting and have somewhat hit a wall, I don't know what else to try. Ill try to explain all my trouble shooting I've done as detailed as I can
I tried disabling SLI, that failed.
Then I tried uninstalling all nvidia software and then running driver sweeper in safemode and reinstalling fresh drivers(still using SLI), that failed.
I then took out the bottom card and just used 1 card(I also rolled back 1 driver version when I did this). this failed as well.
Next I just swapped cards(still using 1 card). This is where things get weird. So now I'm using 1 card, and its the card that was originally the bottom card. Playing BF4 for about 2, maybe 3 hours and no freezing at all. I'm thinking hell yea the other card is just a defective card and that's an easy replacement. I wanted to be thorough with my trouble shooting so me and my friend decided to make him a guinea pig. We put the card that we thought was defective into his computer. He has a similar set up to mine. He played for around 5 hours maybe more and not any single indication of any problems on his system. This worried me so I decided I just need to test mine out more. I get on BF4 and it freezes right away, and it starts freezing more frequently after that. I turned off my OC on my cpu so its stock. No change at all still freezing frequently. Im somewhat at a loss of what to do now. I was hoping that the cards were just defective because that's an easy fix. But that doesn't seem like its the case since the original card worked fine in a different system.
Guinea Pig specs
sandy bridge i5 @ 4.6ghz
my 780 ti
Mobo is some ROG variant micro atx 1155 socket(i dont remember exactly which)
8gb ddr3 1600
750w psu
1440p display @110hz
Sorry about the length of this post I tried to be as detailed as I could. I apologize if I left out any details that would be helpful, let me know if you need to know anymore information. Anything helps even if its a hunch I'm open to try just about anything thanks.
