Hello.
What parts should i upgrade to run Battlefield 3 40 FPS minimum?
My computer specs :
GPU : GeForce 8800 GT
CPU : AMD Athlon 64 x2 Dual Core Processor 6000+
RAM : 4 GB
I am looking for something not really expensive.
Thanks
Hello.
My computer specs :
RAM : 4 GB
Thanks
Any upgrade on that PC won't be worth it.
What settings and resolution will you playing at? What's your budget?
Everything and you'll also have to upgrade RAM because it is DDR2. I'll make a build up for you (that's $600). I'm assumming you're from America by the way.
http://pcpartpicker.com/user/DroPouT1999/saved/2qCl I believe it's about $530. Sorry if this wasn't the budget you had in mind but you didn't have alot of info.
No,im not from America. Im from Europe
But Thanks anyway
look in a 7850 or 7950 and a fx 6300 with 8gb of ram
Okay, sorry about that, where about's in Europe are you located and what's your budget?
Im from Latvia (Eastern Europe) and my budget is about 200 dollars
