Hello there guys.
So i currently have a PowerColor 7870. It runs most games in High and ultra.
Should i upgrade and get the R9 270x and is it faster than the 7870?
Hello there guys.
no its not worth it 270x is not much faster then what you have if you are upgrading get a 280x or better to make it worth while
I would love to get a 280x but my case is to small.
you could get a new case
You could look into a 760 DirectCU or the mini verrsion if you really want something small though its only about 10% more frames increase compared to a 7870 and a bit more in Nvidia optimized games.
The R9 270x is based quite heavily off the Radeon HD 7870, so it isn't a great enough benefit really to shell out for it. The better bang for your buck would come from the R9 280x. Get a new case.
Money does not grow on trees where i live haha. Yea i might have to buy a case.
a 270x and a 7870 are the exact same card
Well to be fair I believe the RealAudio tech they spent have the conference in hawaii explaining should be specific to only the 270x. Not sure if games that have it will cause incompatibility though.
