First off I apologize on the randomness of my build but I built it from bits and pieces as my budget let me.
http://pcpartpicker.com/p/1m3is
I play with a resolution of 1080p and I play World of Tanks, Skyrim, War Thunder, and Arma 3. I've been trying to stream but as you can see it doesn't work so well. My budget is tight at $300 and I'm trying to decided whether to up grade my cpu and mobo, or just upgrade my gpu.
Gpu:
EVGA 760 http://pcpartpicker.com/p/1a7Wj
Mobo/Cpu Combo's:
i5 http://pcpartpicker.com/p/13bU1
FX8320 http://pcpartpicker.com/p/GoEf
If you guys have any advice or better ideas I would love to hear them.
Thanks,
Hellsingsage
