Upgrade questions
I've been wanting to upgrade my desktop to a better video card so I can at least play games like Skyrym  but I don't have the money to build a gaming desktop like I want to so that's why I want to get a cheep but really good video card so I can still use this desktop wile i save up money for the desktop im going to build. I have asked around and most of what I get for an answer dosen't really help.
Here is my Specs to my Desktop.
Dell Inspiron 518 (OEM OS was Windows Vista Ultimate 32-Bit, now it is running Windows 7 Ultimate 32-Bit, and yes I know 32-Bit isnt very good but it works for what I do at the moment)
3 HDDs
Foxconn DG33M04 Motherboard (1.0.3 BIOS)
400 Watt Antec PCU (has wires for a Video card)
4GB of Memory (MAX)
Intel Pentium R Dual CPU E2200
Stock Heatsink
All SATA
Mid tower case
(I have done other upgrades but there mostly fan placements to cool the desktop down, and changed the case so there's not wires everywhere)
What would be the best video card I can put in this desktop? And if possible if I can upgrade the CPU to a quad core what CPU should I get? I just need this desktop to last till I get the money to build a better desktop (for gaming and making weapons for other games) and also so I won't buy a console (I don't like them), I'd rather stay with desktops.
whats your price range for the gpu?
What gpu would you be replacing as well.
Im replaceing the stock GPU that is on the motherboard, and my price range will will depend on how good it is
Upgrading your CPU is possible but getting parts is fairly difficult, the LGA775 socket that your motherboard has is practically dead, and so if you wanted a CPU you'll mostly be looking on Ebay, however upgrading your GPU is still feasible, however we really need to know what sort of budget you are giving yourself. Define what you mean by not having the budget for a 'gaming system'.
So off a 400 watt power supply the 7750 was the only one recommend at that wattage by AMD. Seeing as it is a Dell, I have little hopes of upgrading other parts besides the gpu. In my experience almost every part has non standard connectors to prevent any on but them from servicing it.
Well I found 3 that I think would work but what one should be best? I noticed some have DDR then a number in there discription, would that affect it to work on my desktop or not?
Here is the 3 video cards
1) http://shop.amd.com/us/All/Detail/GraphicCard/HD7750-1GD5-V2?SearchTerms=7750#Details
2) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2941928&CatId=7387
3) http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8511872&CatId=7387
And for what Im wanting to do for a gameing system its going to cost me $700 or so for it
(G)DDR3 and (G)DDR5 refer to the type of memory on the video card. The 5 being the better option. Neither will effect compatibility.
The Asus is the better option.
