Upgrade PC
This is currently what I have:
PCPartPicker part list: http://pcpartpicker.com/p/1JKAM
Price breakdown by merchant: http://pcpartpicker.com/p/1JKAM/by_merchant/
Benchmarks: http://pcpartpicker.com/p/1JKAM/benchmarks/
CPU: AMD A8-3870K 3.0GHz Quad-Core Processor ($89.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing CPU Cooler ($19.99 @ Newegg)
Motherboard: Gigabyte GA-A75-UD4H ATX FM1 Motherboard ($82.86 @ Newegg)
Memory: Corsair Vengeance 4GB (1 x 4GB) DDR3-1600 Memory ($39.99 @ NCIX US)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($59.98 @ Outlet PC)
Case: Cooler Master Elite 430 ATX Mid Tower Case ($24.99 @ Newegg)
Total: $357.79
I also have a 600 watt power supply and a EVGA GTX 570
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130593
What should I upgrade for playing the new games coming out such as Battlefield for or The Division?
i would just do a gpu upgrade  to 7970/x280 or 770gtx. Then if you have money get 8350 fx and motherboard upgrade
Which motherboard would work good with the 8350 fx?
ive been told either Gigabyte UD5 990FX or ASUS SABERTOOTH 990FX R2.0 AMD 990FX (Socket AM3+) Motherboard or MSI 990FXA-GD80 AMD 990FX (Socket AM3+) Motherboard But these boards are £100+ and there may be better motherboards for you
