Should i upgrade to a GTX760 from my 7870 ?
Are you having issues with your 7870?
No
You are not going to get a performance increase jumping to a card that has allmost the same power so no.
Wait for the new AMD cards if your itching to upgrade and see what there like.
well i do like PhysX & i rather have a card use that then my CPU.
Why not a 770 instead? At least you would get a performance boost...
Yeah but i like the 250$ range much better :)
It's your money...Just fail to see the logic of wasting $250 to stay in the same place. But, like I said, it/s none of by business.
Cheers.
