So ive got a off the shelf acer witting around, my 12 year old cousin was so mind blown when i let him play battlefield on my new PC, he immediately said "My play station doesn't like this game as much as you computer" im excited to get yet another family member to switch too the dark side of the PC overworld. He does help out at my auto shop and i give him some moola when he helps to get him started. But i would feel terrible making him spend his money to get a low end PC... SOooo i was wondering, my Acer has a quad core APU A6 3620, 1 tb hdd, 6gb of unknown ram =p and the part im worried about, the psu is only 220 watts. and to make the experience smoother i wanted to add something like a 7750. SO my question is will the psu be able to handle it and will the APU's graphics automaticly disable once the card goes in?
thanks so much :)
The highest hybrid xfire compatible card you can use with those older apu's is the 6670. The psu should be ok - low end cards just run off the pcie bus and consume very little power.
http://s49.radikal.ru/i125/1207/d0/0ac0e269fad3.jpg
7750 wont be hybrid xfire compatible and wont be much better than the performance of the apu itself.
As for the workload being shifted to the discrete gpu once installed etc. Yes, once drivers are installed that gpu will handle the graphical workloads. Nothing gets 'automatically disabled' so to speak its just that the gpu will handle the tasks. (unless as first stated a 6670 is used in which once hybrid sli is enabled both the apu and gpu work together on the workload). Only thing needed for adjustment is in the BIOS - dual graphics option on some boards. Or via CCC.
Otherwise - you could grab a another psu and something cheap like a 7850???
in short -
a) add in a 6670 for hybrid crossfire & keep existing psu,
or
b) upgrade psu and add in cheap card like 7850, gtx650 etc.
a<b in gaming performance but way cheaper
do you think the A6 will bottleneck anything, with and without crossfire 7770's?
single card no, xfire most likely.
