Hey there,
So I've made the mistake of buying the asrock 970 pro3 r2.0 mobo with its crappy 4 + 1 Phase design which even after a replacement still throttles my cpu cause massive frame drops in games. Now I'm going to get an upgrade and I would like some help, I got a budget to arround 120 euro's and the Im using the AMD 8320 black edition 3,5ghz 125tdp processor.
Now I've found this beauty
http://tweakers.net/pricewatch/314670/asus-m5a99fx-pro-r20.html
Is this mobo good enough to not throttle my cpu and or not allow me to OC if I so desire (but my cpu has a auto turbo on it which clocks it to 4 ghz when needed)
if there are better alternatives please do tell me, but id like atleast a 8+2 vrm phase design to avoid the heat
