Budget: arround 500$
USA
Intel Core i3-4170 CPU @ 3.70GHz stock cooling
Installed memory RAM: 8.00 GB by CORSAIR
AMD Radeon (TM) R9 380
Motherboard: GIGABYTE B85M-DS3H-A
LEPA N500 powersupply
SSD 240GB Patriot
Cooler Master HAF 932 Full tower
Monitor: 27 inch imac using display to mini display port adapter 2560x1440
Sounds: s.m.s.l sa-50 amplifier with FLUANCE SX6 High Definition Two-Way Bookshelf Loudspeakers
I want to upgrade it a little now and a little bit more during black Friday/cyber Monday.
Eventually I'll need it to run two monitors, but that's not as important as keeping overwatch over 120 fps. The problem is I run multiple programs at a time and don't like having to shut them to play Overwatch. Clearly a CPU would help that, but I just wanted more thoughts on my build in general and if you could direct me to a CPU.
Again any advice on upgrading my build would be greatly appreciated.
