Upgrade GPU or CPU First?
So I'm looking to upgrade my system.. its been 6 months or so since i put it together and want to overhaul it a bit since i have more funds available. Question is, which would be more feasible? Upgrade the CPU or GPU.
Current CPU: Intel i3 3220
Upgrade CPU: Intel i5 3570K
Current GPU: EVGA GTX 660 SC (OC'd to 1215Mhz - stock boost is 1111Mhz, temps are around 68-70 full load and is pretty loud..)
Upgrade GPU: MSI GTX 760 GAMING TF (Ive seen reviews on this on TechpowerUp and it seems the best choice out of all the non-reference cards as its the quietest while still being relatively cool even OC'd and keeps up within 1FPS in most cases.)
Im planning on doing both eventually, but only have the funds for one or the other. WIth the GPU i have to upgrade my PSU as well so im looking at a 350$ upgrade (Only about 150$ if i can sell my GPU and PSU *Anyone interested? The PSU is a Seasonic M12II 620 80 PLUS BRONZE*) Or only a ~250$ for the CPU and alt heatsink.
I game mostly i also do some Adobe PS work, but I want to get a capable CPU to keep bottleneck to a minimum.
Thanks.
biggest improvment you'll see is the GFX card, but  im not sure if your cpu will bottleneck now, i highly doubt it tho, i3 pretty capable.
Upgrade the CPU. If you upgrade the GPU. You're going to see a Huge Bottleneck. Plus it's a really dumb Combination. If you put the 760 with the i3 it'll be like putting a Rocket on a Tricycle. It'll go really fast till it explodes.
If you plan on doing both, it doesn't really matter.
Lemme rephrase that.. i plan on doing both eventually... it might be in a month it might be in 3 or 4 months.
Maybe i should of asked more of would keeping my i3 and upgrading to the 760 still provide ample performance gain (enough to even warrant a need to upgrade) and not suffer from bottlenecking of the CPU.
Personally, I would go with the 760, it's a reasonably good card. And there are the new AMD offerings to consider.
The reason I would suggest this is not because of the performance gain, but because you can have any number of cheaper platform upgrades (e.g FX6300 and 970 chipset motherboard) which might be a suitable alternative versus an i5.
If you happen to have a Z77 motherboard, I would stick with the 3570K as the chosen upgrade path. You might want to consider other i5s, if you're not on an overclocking motherboard.
So yeah, 760 first, imo.
i have some question before i can give a clear answer frist do you have a lot of programs on your back ground and second i don't how fast you will get enough money to upgrade the second part and third what which games do you plan on playing on this system ?
( if you have a lot of programs on your computere and you are fine whit low setting gaming on games like BF4 then i would go whit a new CPU if don't have a lot of programs in you back ground and like to game on higher settings i would go for the GPU)
Depends on what games you play OP on which one to upgrade.
I would consider waiting for AMD's offerings regarding the GPU. 300$ for the 280x/280, which will probably kill a 760.
i would get the Cpu first because The i5 price only go up and down like $20 bucks but video cards lose value way quicker.
Thanks for all the feedback.
I did look at the option of going to AMD, I'm just unsure about it. Im not loyal to any brand so i dont really care... but does the 6300 even compare to the i5? I thought the 8350 was the equivalent. Also have to factor in the TDP for AMD is higher than Intel's 77W as opposed to 125W for the 8350. My current MOBO doesnt allow OC so i would have to upgrade that as well if i wanted it. Which honestly I don't have enough confidence in myself to do it.
I was also very intruiged by AMD's latest release, especially their mantle project. In which case i would skp the GPU upgrade for now, get either an AMD Mobo combo + heatsink (which i would rather avoid since i would have to redo all the drivers in windows) or just slap an i5 + MOBO + Heatsink (Since intel i5 ivy bridge series dont have combos..only the new haswell ones do at least on Newegg *perferred since i have free 2 day shipping*).
As for games.. everything thats coming and is out i play :). And while im alright with FPS, i want that extra umph in games that the 760 gives over the 660. Not to mention my EVGA's 660 SC is quite loud and obnoxious.. while the MSI 760 TF has a difference of 2dBA in idle and full load... (25dB idle, 27 full load).
Unless you are getting an 8350 the i5 is the best and most cost effective option for you.  I would personally for a gpu wait like 2 weeks a when amd releases and get a R9 280x for 299 or pick up a gtx 770 because there is a high chance the price will drop.  I would still get the graphics card first.
I think thats what I'll do. Wait a couple weeks, save some extra cash and get the new 280x. Then ill be set for quite some time :). Then get the i5 and possibly new MOBO.
http://www.youtube.com/watch?v=qIT9uLDjZcg This is a really good video to show the compasion between 2 cpus (AMD Athlon and i5) with serveral different cards.
its insanely hard to bottleneck. even moreso with a Nvidia card 'cause of Physx on the card.
upgrade the GPU first.
Why d you need to upgrade the psu? 620W should be plenty.
The amperage on the +12V rail is only 24. The minimum for the 760 is 30. Which sucks because this PSU has been very reliable for me.
That would be very applicable for me.. if all i did was turn on my PC and game xD. I do some productivity stuff too, and it fails to go over the sheer performance of the Chip versus the other which will translate in how smooth and efficient the OS operates. Even with my i3 I get hiccups when working with CPU intensive programs and multitasking (having 4-5 tabs open in chrome and be compiling an android application). But it does relay the point that in gaming its not entirely necessary until you get more capable GPU's, which i will be.
It has two twelve volt rails. It should be more than enough, if I'm not mistaken. Someone correct me if I'm wrong though.
O.o I didnt see that... If thats the case you just saved me $100!
Also didnt realize it had a 6+2 PCI-E.. saved me from having to buy another cable.
