So your saying that I could use the OCZ for a short term PSU until I get the money for a better one??
Ya I know, but I definetly want to get a better PSU than that as soon as possible.
And thanks for taking the time to write that, it was very helpful.
Yeah, you could probably get away with running an OCZ power supply for a while. I haven't heard anything bad about their build quality or reliability necessarily. I've just heard that they can be loud because of coil whine. Their PSUs probably do work just fine, but they might get tiring to listen to after a while, and if you get one and it doesn't have the coil whine issue, then there's probably nothing to worry about in the first place.
Good
Just remeber with the "LinusTechTips" is reliable thing, he is great at reviews, but it is his job to sell the products to people, I doubt he is going to go out there and read a bad review about a product.
Ya
that is the thing about reviews, you gotta keep in mind who they work for, that said, revies are good places to see the components to make your own decision
