(updated) my pc build. give me your opinion
here is my PC build that im going to be taking to compete at skills USA TEXAS, I need help on naming my computer, to compete in skills usa you need to name your computer and i cant think of a same so HELP ME OUT HERE! :)
here is my $1200 build
case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119245
CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113285
Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131876
GPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121656
RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231489
HDD
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236339
SSD
http://www.newegg.com/Product/Product.aspx?Item=N82E16820239045
Power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817152042
CPU cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835106187
burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
Extra add on's
http://www.newegg.com/Product/Product.aspx?Item=N82E16820223103
http://www.newegg.com/Product/Product.aspx?Item=N82E16800888027
http://www.newegg.com/Product/Product.aspx?Item=N82E16835119067
http://www.newegg.com/Product/Product.aspx?Item=N82E16835345035
pcpartpicker.com
+1
Too much of a hassle to go through that.
First, post your budget. Then use PCPARTPICKER.COM
After that, I'll come back to you to give advice. But I did look at one thing in your build; the PSU.
Never ever, and I mean NEVER, get a Raidmax PSU, unless it's a 1000W 80+ Gold fully modular one for below $50. Never. Do you want to fry you parts?
just posted my budget.... and sorry about the psu... ill change it
So $1200 is your max? Oh, and, don't worry, not mad. But, you still picked a Raidmax PSU again. i didn't say that specific PSU, I meant the whole brand. Try something like SeaSonic, XFX, Antec or Corsair.
Here, I put together a build for you. I didn't think I could fit all that in a $1200 budget, though it is a little over budget before rebates, but after rebates, it's under it.
You can't buy the extras you wanted with this build, the Storm Trooper looks badass anyways. If you still want them, you can always drop the SSD, or swap the i5 for an FX-6300( I actually would prefer this, but the i5 fits anyway. As far as perf. loss from choosing an FX-6300, probaly 5-6 FPS at most). But seriously, would you swap out functionality for looks?
I know the cooler could be better, but this is really all you need. Plus it keeps it in the budget.
If you want, you can drop the PSU and get this to save some money for those extras, a 750W is plenty powerfull. Or this if you want a modular PSU.
Lastly, I don't recommend changing the case much. The Gigabyte is huge, but it's a good deal. That Trooper can fit it, but others cant. The length of the card is 285mm, so if you want a cheaper case, pick something with more room than that. Two cheaper cases I know off the top of my head right now that can fit it is the Zalman Z11( 290mm) and the Cooler Master Haf 912( forgot the length, but it wont fit normally. You'd have to remove the modular hard drive cage for it to fit, downside is you'll be left with only 2 internal drive bays).
