Upcoming Build
Input? Suggestions?
I'll be using this build for gaming, video editing, photo editing, and rendering. I do plan on eventually adding a second video card, so keep that in mind.
I have already purchased the video card, power supply, monitor, keyboard, and mouse. Everything else is interchangeable.
PCPartPicker part list: http://pcpartpicker.com/p/2NpES
CPU: Intel Core i7-4770K 3.5GHz Quad-Core Processor ($249.99 @ Microcenter)
CPU Cooler: Swiftech H220 55.0 CFM Liquid CPU Cooler ($99.99 @ NCIX US)
Motherboard: Asus Maximus VI Hero ATX LGA1150 Motherboard ($189.99 @ NCIX US)
Memory: Corsair Dominator Platinum 16GB (2 x 8GB) DDR3-2400 Memory ($294.00 @ Amazon)
Storage: Samsung 840 Pro Series 256GB 2.5" Solid State Disk ($209.99 @ Amazon)
Video Card: XFX Radeon R9 290 4GB Video Card (Purchased For $468.84)
Case: Cooler Master SGC-5000-KWN1 ATX Full Tower Case ($129.99 @ Newegg)
Case Fan: Noctua NF-F12 PWM 55.0 CFM 120mm Fan ($25.99 @ SuperBiiz)
Power Supply: Corsair RM 750W 80+ Gold Certified Fully-Modular ATX Power Supply (Purchased For $129.99)
Monitor: BenQ XL2420TE 144Hz 24.0" Monitor (Purchased For $397.07)
Keyboard: Razer Blackwidow Ultimate 2013 Wired Gaming Keyboard (Purchased For $109.99)
Mouse: Razer Naga 2012 Wired Laser Mouse (Purchased For $72.98)
Total: $2404.80
That is indeed a very nice build.  You might want to look into a WD Black drive if you need more storage, but everything looks good otherwise.  You can probably find some cheaper, 2400 clocked RAM if you wanted to save some money.
Ahh, forgot to mention, I've got three 1TB drives I'll be transferring over from my current system for mass storage. I may replace those in the future, though. Any recommendations on other 2400MHz memory?
If money is not a problem you should scrap the 840 pro and get something better. like a pci-E ssd :D
http://www.newegg.com/Product/Product.aspx?Item=20-227-740
http://www.newegg.com/Product/Product.aspx?Item=20-227-744
