I have an A10 7700k APU and bought 2400mhz ram for it (old technology I know), but my motherboard sets the clock 1333mhz when booting into any OS. I wondered if it was a fail-safe kinda thing(being that motherboard is of an older persuasion) and was doing this automagically so I decided to try out 2133, 1886 and 1600mhz. With all configurations I had the same problem. When entering the BIOS it displays “8gb@2400mhz”, but also 1333mhz on the same page?
To be frank, I’m completely new to this. Thus far all I have done is used the GUI to change RAM speeds, but am I going to have to start messing round with voltages to get results, or am I missing something crucial (like a toggle or setting) ?
Information that might be helpful:
AMD A10 7700k (3.4 ghz)
Corsair Vengence Pro (2 * 4GB) DDR3 2400mhz CL11 XMP RAM # will the “XMP” part effect this, as I’m using D.O.C.P
Asus A58M-E motherboard.
Thank you to anyone who takes the time to help me out. Don’t feel as though you need to go above and beyond, as I can always repurpose my hardware, although it would be nice to have it running as it should be.
Thanks
