Unreasonable frames for higher end pc
Anyone can spot any bottlenecks in my build, This isnt a new pc but as much money as i spent on it i should get more frames than im getting. In arma ii for example in a city i get at max 20fps on med. When zooming in a can at times jump down to >5 fps.
Any help or sugestions would be of much help for any upgrades for its due for a refresh.
  • Manufacturer:      Custom
  • Processor:            AMD Phenom II X4 820 Processor (4 Cores), 95W, O.C. 3.0GHz
  • Cooler:                  ULTRA CARBON X3 COOLER MULTI-SOCKET
  • Memory:               4096MB XMP Corsair XMS3 DDR3 Dual Channel 1333MHz
  • Hard Drive:           59 GB OCZ SOLID SERIES SSD
  • Video Card:          2X AMD Radeon HD 6870 by MSI (6870R Twin Frozr ii) In Crossfire Config.
  • Monitor:                Dell SE198WFP 16:9 (Digital) + Acer 19" (Analog)
  • Optical:                 Lite ON 18X DVDROM IDE OEM
  • Sound Card:        Speakers (Realtek High Definition Audio) (Onboard)
  • Speakers:            Headphones:TurtleBeach 5.1 Z6a + Klipsch 5.1 Gaming surround System
  • Keyboard:            Logitech G15 Gaming Keyboard
  • Mouse:                Razer Diamondback 3G
  • Surface:               Legacy AMD-ATI Rubber Flex Mousepad
  • OS:                       Windows 7 Ultimate 64-Bit
  • Motherboard:     Gigabyte 870A-USB3 AMD 870 Socket AM3 Motherboard
  • Power Supply:    ULTRA LSX 750W PSU
  • Case:                   NZXT M59 Mid Tower Case
  • Media Reader:   Ultra USB 2.0 MD3 5.25" Multi Function Panel
  • Extras:                 Cold Cathode Blue Lightning Pattern ; Blue Modular LED Strip ; Fan-Attic Switch
Well, your CPU isnt the best of the best, and arma uses a LOT of CPU power, it might be bottlenecking a bit in arma. Arma is just very demanding, for example, i have it set on high with an i5 2500k oc'd to 4,3Ghz and an XFX 6870 and i usually get (depending on the mission) around 20-40 in city's, mostly sitting around the 29 fps.
I was thinking of just a motherboard and CPU refresh. My motherboard does 16x 4x when in crossfire so idk if that could be a reason as well. I think its the FX8350 logan has been talking about and i may do that.
Yeah, i think that might be one of the best options, because the GPU's will last you for a while and arma (hopely) doesnt use more than 4 gigs of ram. Also, that probably isnt the reason, you see, my graphics card handles the game fine on medium to high settings with AA toned down and a few other very demanding things turned off.
Before making the decision on the FX-8350, try finding some benchmarks for arma with other cpu's.
i personaly would also upgrade your RAM to faster stuff. also going to 8gigs wouldnt hurt, the more modern games are using more and more ram nower days,for example farcry 3 like's you to have 6gigs set aside ideally. and what ever a game wants you always need abit more for your OS and background apps on top of that to be sure that everything in the RAM department is running smoothly.
