I’m new to unraid, so this may be a simple solution, but my search results havent given me the answer. Is there a way to give a second unraid account access to my unraid server? or perhaps a secondary way for them to connect to it outside of unraid connect? I can access it outside my network with my account, so that isn’t an issue.
I don’t think so. From my understanding only root can log into the webgui. You can create other accounts, but those are used for SMB and such for file access permissions.
I don’t mean in terms of root/folder access. I’m talking about the unraid connect webgui that you can access from anywhere.
Xradeon is correct only root has gui access by design.
UnRaid is not meant to have remote access either, it has not been hardened.
but unraid connect is a thing?
Huh, new to me. Used to be that they always said not to expose the mgmt to internet access. Guess the are balancing user want with security need.
I am used to living without remote access. Not missing what i never had.
