I’m planning to build a Unraid server with my PC
Ryzen 7 2700x
Gigabyte Aorus X470 Ultra Gaming
32GB DDR4 3000
GTX 980 TI
GTX 1060 6GB
To deploy, two windows VMs with graphics card passthrough for each, will I need a third video card just for unraid?
https://wiki.unraid.net/UnRAID_Manual_6
probably not guessing you can manage via web gui after install
You won’t need a GPU for the unraid host once you can access the web gui. Even then, you can enable SSH and get the same output by using an SSH client to connect to your unraid host.
Install unraid, once you can get to the web gui, you’re good to passthrough all the GPUs
thanks. this is very good to know…
This topic can be closed
