I’m having a bit of an issue with some of my network gear. I’ve got a bunch of short runs (<15ft) on a mix of CAT5E and CAT6 that’s been autonegotiating to 100 HDX. I’m encountering this on both a Unifi Switch 24 and a Unifi Switch 8. Moving to a different port (switch or device) doesn’t help and the links worked fine on an older Netgear dumb switch. Different cables also do not help.
I’m far from a networking pro, so I’m looking for some troubleshooting advice first.
EDIT: I was able to set link speed to 1000 FDX with ethtool -s enp11s0 speed 1000 duplex full, but that’s not sticking over a reboot.
I’m not familiar with the unifi product but there should be a way to check port stats, port utilization and port errors. May shed some light on some issue.
May 21 12:05:00 OfficeSwitch2ndfloor user.notice syswrapper: [apply-config] using fast apply
May 21 12:07:54 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Down: 0/2
May 21 12:07:54 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (2) inst(0) role changing from ROLE_DESIGNATED to ROLE_DISABLED
May 21 12:07:57 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Up: 0/2
May 21 12:07:57 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (2) inst(0) role changing from ROLE_DISABLED to ROLE_DESIGNATED
May 21 12:13:28 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (2) inst(0) role changing from ROLE_DESIGNATED to ROLE_DISABLED
May 21 12:13:28 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Down: 0/2
May 21 12:13:35 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Up: 0/4
May 21 12:13:35 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (4) inst(0) role changing from ROLE_DISABLED to ROLE_DESIGNATED
May 21 12:13:39 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Down: 0/4
May 21 12:13:39 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (4) inst(0) role changing from ROLE_DESIGNATED to ROLE_DISABLED
May 21 12:13:44 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Up: 0/2
May 21 12:13:44 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (2) inst(0) role changing from ROLE_DISABLED to ROLE_DESIGNATED
May 21 12:15:06 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (7) inst(0) role changing from ROLE_DESIGNATED to ROLE_DISABLED
May 21 12:15:06 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Down: 0/7
May 21 12:15:10 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Up: 0/7
May 21 12:15:10 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (7) inst(0) role changing from ROLE_DISABLED to ROLE_DESIGNATED
May 21 12:15:15 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (2) inst(0) role changing from ROLE_DESIGNATED to ROLE_DISABLED
May 21 12:15:15 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Down: 0/2
May 21 12:15:18 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Up: 0/5
May 21 12:15:18 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (5) inst(0) role changing from ROLE_DISABLED to ROLE_DESIGNATED
May 21 12:15:21 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (5) inst(0) role changing from ROLE_DESIGNATED to ROLE_DISABLED
May 21 12:15:21 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Down: 0/5
May 21 12:15:24 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Up: 0/2
May 21 12:15:24 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (2) inst(0) role changing from ROLE_DISABLED to ROLE_DESIGNATED
May 21 12:18:50 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (2) inst(0) role changing from ROLE_DESIGNATED to ROLE_DISABLED
May 21 12:18:50 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Down: 0/2
May 21 12:18:53 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Up: 0/2
May 21 12:18:53 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (2) inst(0) role changing from ROLE_DISABLED to ROLE_DESIGNATED
May 21 13:06:31 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Up: 0/4
May 21 13:06:31 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (4) inst(0) role changing from ROLE_DISABLED to ROLE_DESIGNATED
May 21 13:06:32 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (4) inst(0) role changing from ROLE_DESIGNATED to ROLE_DISABLED
May 21 13:06:32 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Down: 0/4
May 21 13:06:34 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (2) inst(0) role changing from ROLE_DESIGNATED to ROLE_DISABLED
May 21 13:06:34 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Down: 0/2
May 21 13:06:45 OfficeSwitch2ndfloor daemon.notice switch: TRAPMGR: Link Up: 0/4
May 21 13:06:45 OfficeSwitch2ndfloor daemon.info switch: DOT1S: Port (4) inst(0) role changing from ROLE_DISABLED to ROLE_DESIGNATED
This is the output. Clearly not very helpful.
Port 2 is my workstation, port 4 is the port I used to connect the Netgear, port 7 is the management interface for my server, I was having trouble with the server grabbing DHCP, but I guess the server just hadn’t come up yet.
EDIT: I’m an idiot.
I don’t know how that got set, but checking the allow auto-negotiation setting solved my workstation.
Usually how it goes. I’ve wasted whole days at work over stupid shit like that before. Well, maybe not a whole day but you get the point. Murphy’s Law seems to strike me often.
I just installed Ubuntu (for the first time in many years, actually) on my test box and noticed that it defaulted the NIC to 100. Checking the auto-negotiation and a reboot fixed it for me as well.
Is this normal behavior for network-manager, or is this some kind of bug?
Do you know if these cables run over top of any electrical wires of flourescent light ballast? We get this sometimes at a meat packing plant who insist on running their own network cables.
