Undervolting Intel 4771
I recently picked up a 4771 and have been trying to get the temps down.
I have an H100i cooler with an ambient temperature of 26 degrees C
At this ambient temp, Idle temps are around  30 degrees C and max load temps with intel burn test set to use 4GB of memory for 25 sets are around 75.
To try to cool it down even further I have a negative core offset voltage of 0.080 and things have been stable so far. But I did have a few questions. First off, are these temps too high? I have a feeling I may need to reseat the cooler with better paste then what came on it from corsair.
Secondly, what is an IA Offset voltage? When I open up hardware monitor with all stock settings it stays at zero, but with the under-volt it have been at  +1.9663 all the time, I hope this isn't bad for the chip.
Thanks in advanced,
Mr. FOX
