Under Going Build Feedback Appreciated
Specs:
  • CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor
  • Cooler: Corsair Hydro Series H60 74.4 CFM Liquid CPU Cooler
  • Mobo: Asus Maximus V Formula EATX LGA1155 Motherboard
  • RAM: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1866 Memory
  • HDD: Samsung Spinpoint F3 1TB 3.5" 7200RPM Internal Hard Drive
  • GPU: EVGA GeForce GTX 660 Ti 2GB Video Card
  • Case: Cooler Master HAF XM (Black) ATX Mid Tower Case
  • PSU: SeaSonic 850W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply
Post what you think of it.
Looks great, but maybe 16 gigs is a bit overpowered? Also, the PSU might be a bit much.
If you're OCing get the h80 over the h60, you can get some of the difference by drowgrading the RAM to 1600 (you won't notice it) or the PSU (750w will still do SLI 660tis if you upgrade later)
I'm planning on getting a second 660ti in the future but now that I think about it 16 is a-bit much.
Thanks for the feedback!
And about the PSU I can find another Seasonic 750wt for the same price so I might as well.
Build With Revisions
Specs:
  • Cooler: Corsair Hydro Series H80
  • RAM: G.Skill Ripjaws X Series 8GB (4 x 2GB) DDR3-1600 Memory
