Unable to setup surround at proper resolution?
So, I'm trying to setup a 3x1 surround configuration. I have a Gigabyte GTX960 4gb and I've done surround before with different monitors. The monitors I'm currently trying to use are a HP 1600x900, a Samsung 1600x900 and an IBM 1600x1200 (downscaled to 1600x900). It should be able to do the full 4800x900, but the only resolution that shows up in the surround config menu is 3072x768! This same setup has previously done surround on 4 monitors at 5120x1024 (4x1280x1024) no problem, and one of those wasn't 1280x1024 native either. Anyone know why I cant do the proper surround? Any help is appreciated. Note:this setup has 7 monitors in use, I'm only concerned about these 3 surroundering. I can post screenshots of different things, or images of the setup if that helps.
