using windows 10 pro but im not sure if this is something on server side or client side that is causing the issue.. here are the windows command outputs for the client system..
Run the other command that shows indirection table? Did you disable RSS on the adapter that supports it since this looks like a mixed RSS and non RSS config?
as for disabling the rss i couldn't seem to figure that one out for the life of me through all my searching of the web tho possibly something stupidly simple i am overlooking. also dont know if this is what you are looking for in the pic
ok got the rss disabled finally on all nics
Reboot then try to xfer some files and run the command from reply2? Is it RSS false across the board from the first get-smb command?
yes it is now thought i posted that... hmm
got it working Wendell.. sadly server side issue and something linux has yet to fully support for some odd reason (or at-least the distro i use)
