I have an array that I am trying to convert to BTRFS Encrypted from BTRFS.
I emptied a drive and have been trying to format it for a while now. My issue looks to be that the clear partition button does not come up.
Hardware ? OS (I see unraid as tag) ? Commands used?
It’s running under Unraid. I haven’t done anything in the terminal yet just to be cautious, I might be doing something wrong. The hardware is consumer parts built 4U server Drives are 10-12TB WD & Seagate.
I dont run BTRFS but probably best to read the man on it and delete via comand line not sure how supported it is on Unraid as I have only ever done ZFS on unraid.
not sure if this will help
So it looks like I was making a mistake. I had to set Unassigned Devices plugin to destructive mode. There is a tiny gear icon in the corner (made even tinier by resolution scaling). Thanks for the help @mutation666
