Ultra X3 ULT40312 850-Watt Power Supply
Will a Ultra x3 power a http://www.newegg.com/Product/Product.aspx?Item=N82E16814202103   and i onlt got 1 8 pin and i think i need 2 so will this work http://www.amazon.com/PCI-Express-Video-Y-Splitter-Adapter-Supply/dp/B00A3OVG4W/ref=sr_1_1?ie=UTF8&qid=1402493248&sr=8-1&keywords=8+pin+pcie+to+8+pin+y+splitter
55 amps on the 12 volt rail is pretty weak.
it only provides 6 pins for pci-e which is really odd. it might work , but if i were you i'd get a new power supply that had the 8pins i need instead of having to buy extra cables. it could work but it would be at a risk of fire. esp since the PSU isnt even bronze rated.
it has 2 8 pin pcie spots on it just dont have the cables anymore
Would this work as a upgrade http://www.newegg.com/Product/Product.aspx?Item=N82E16817438018
Yep, that would work nicely.
