Type | Item | Price |
CPU | AMD Ryzen 5 2600X 3.6 GHz 6-Core Processor | $191.50 @ Amazon |
CPU Cooler | Noctua NH-L9a-AM4 33.84 CFM CPU Cooler | $39.90 @ Amazon |
Motherboard | ASRock Fatal1ty B450 Gaming-ITX/ac Mini ITX AM4 Motherboard | $124.99 @ Amazon |
Memory | Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3000 CL16 Memory | $96.99 @ Newegg |
Storage | Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive | $109.99 @ B&H |
Video Card | XFX Radeon RX 5700 8 GB Video Card | |
Power Supply | SeaSonic FOCUS SGX 650 W 80+ Gold Certified Fully Modular SFX Power Supply | $126.99 @ Amazon |
Monitor | Acer H236HLbid 23.0" 1920x1080 60 Hz Monitor | |
Monitor | LG 25UM58-P 25.0" 2560x1080 60 Hz Monitor | $149.99 @ Amazon |
Prices include shipping, taxes, rebates, and discounts | ||
Total | $840.35 | |
Generated by PCPartPicker 2021-01-05 21:59 EST-0500 |
Wanting to upgrade my ultra wide. Well actually buy a bigger one use the current one as a secondary screen (Possibly in portrait mode). I know I want 34" and preferably 1440p. But I got a few issues. I have the Freddie Desk from Ikea, so I can fit a monitor 51" wide, 11" deep, and 19.5" tall. Some 34" ultra wides are a bit too tall. Im open to other suggestions as well. Would like to stay around $600 if possible, I might need to buy a monitor stand for my current ultrawide if I need to put it in to portrait mode. Looks like VA panels are a bit cheaper. I know they dont have the viewing angles of IPS, but are they as bad as TN? I had a laptop with a TN panel and wanted to gouge out my eye. Trying to figure out if going with the VA panel with the higher refresh rate is worth it, or should I stick with the IPS panel with the 60 Hz refresh rate?
Use cases, will be used with my MacBook Pro, gaming PC and Plex server. So its needs to have at least 3 inputs.
Below are the monitors I found that should fit.
- https://www.amazon.com/LG-34WN80C-B-inch-Connectivity-Compatibility/dp/B07YGZ7C1K/ref=psdc_1292115011_t2_B0812DKDD9?th=1
- https://www.amazon.com/Monoprice-Zero-G-Curved-Gaming-Monitor/dp/B07SH173T9/ref=sr_1_22?dchild=1&qid=1609800927&refinements=p_n_size_browse-bin%3A3547808011%2Cp_n_feature_fourteen_browse-bin%3A17751789011%2Cp_n_feature_thirteen_browse-bin%3A17751774011%2Cp_72%3A1248879011%2Cp_36%3A-60000%2Cp_n_condition-type%3A2224371011&rnid=2224369011&s=pc&sr=1-22
- https://www.bestbuy.com/site/gigabyte-34-led-ultrawide-wqhd-freesync-monitor-with-hdr-hdmi-displayport-black/6437138.p?skuId=6437138
