TL;DR
Having a optane 905p and try to share it with another PC, what hardware should i buy and what software/architecture to get a ultra low latency setup. Low latency is more important to me than raw throughput (1250MB is more than fine, even less)
Okay, why i need such thing?
Iam a developer and most of my work (during development) is running in docker-containers with file mounts. Spinning up multiple containers at the same time (microservices) sucks d. on a local pc (already have a TR3960x). Sometimes multiple containers also need the same mount-points (Iam a freelancer and this setup is pretty common).
Fast prototyping, so my IDE (PHPStorm) and the containers having the changes almost immediately is key.
Options (software):
- Fine-Tuned NFS
- Some cluster FS like ocfs2 / lustre
- Something i don’t know yet
Options (Connection point2point):
- 10/40gbe network - what nic?
- Fibre channel 16?
- Usb/others?
Goal:
Having a “identical” container running locally and remote with one filemount.
Price goal <1000 EUR
Thx for your help!
Cheers
Alex
