Ultimate YouTube Box
Hello there everyone! I am a budding YouTuber and a gamer like many of you out there. I currently use a laptop that no longer suits my needs as a gamer and an editor. So I decided to save up for an amazing system that has amazing gaming and editing power, along with silence optimization and cooling efficiency. When I make videos I would often hear the roar of my laptop's fan and the gameplay is usually laggy even without a recording system. So as you can very well tell I want an upgrade. I want nothing but the very best at my price point of around 2000-2200 dollars.You may say that that is quite a lot, however I believe my build reflects the fact that it would be well spent as I have taken hours of thought into each of the materials that I need. So check it out and tell me what you think! If you find anything you think could be changed for something better or if there is anything that I should add then tell me! Check it out here: http://pcpartpicker....an/saved/ccJnTW
P.S. I know there is a Wireless Adapter, I need one because there is already a router in my house
P.P.S I took some advice from some guys on other Tech sites so I hope you like this improved version!
100$ cheaper. As quiet or maybe even quieter with same CPU performance (no overclocking tho) and better GPU. Same performance as a GTX 780.
Hope I helped :)
I'd try to shoot for some higher clocked 2x8GB ram kit.  It will help with the video rendering if you do a lot of editing.
k95 rgb in august !
DO NOT BUY THOSE SPEAKERS!! I bought a those maybe 4 months ago and 2 months later they broke. While playing music the sub made a loud pop and they never turned back on. In the $40-$50 price range these are much better. http://www.amazon.com/Limitless-Creations-X643-Satellite-Subwoofer/dp/B00711MUTA/ref=sr_1_1?ie=UTF8&qid=1402388656&sr=8-1&keywords=limitless+speakers
Id also recommend that you spend less on the mouse/keyboard and fans for now and buy 16gb of ram and a R9 290 and honestly you be better off moving to the 2011 platform to keep the system current longer.
Also if you going to be doing a bunch of uploading LAN is mandatory, wifi is just not going to cut it.
I would go with something like this, http://pcpartpicker.com/parts/partlist/
