Hello Fellow L1 geeks,
I have found, in my humble opinion, the ultimate home server machine for cheap. It is the dell precision 7750.
Here are the specs:
- Intel i7 10850H / i5 10400H / Xeon M (All three have intel GPU)
- 4 Ram Slots and all 3 CPU SKUs can do 128 GB
- Upto NVIDIA RTX 5000M (16GB), you can get RTX 4000M (8 GB) or RTX 3000M (6GB)
- 4 m.2 slots
- 2 thunderbolt ports: capable of creating the thunderbolt cluster that WENDELL spoke about in a video
- It only has gigabit lan, I am using a usb to 2.5G adapter.
I have the intel GPU running Jellyfin, the NVIDIA GPU running Ollama and Stable Diffusion and the CPU manages all other containers.
The best place to buy: dellrefurbished website. Get it on the days you have a sale, can get it for about 500 - 600.
Comes with a battery !!! => No worry about power outages / fluctuations. Hook it to a decent UPS and you have a system that can have a power backup system easily for hours.
The only feature I wish I could do is install proxmox and use vGPU to split the NVIDIA GPU for Ollama and other projects that can use a GPU, WHICH IS THE REASON FOR MY POST. Having the ability to split the GPU means even more utilization of the machine.
WENDELL, please take a look at this if you get a chance. There are other laptops that have 2 GPUs and I believe laptops are great platform for self hosting.
